Question about MK2 tail fog lights????
General discussion for Scirocco owners
Tempest
AW: Question about MK2 tail fog lights????
Beitrag von Tempest »
What bulbs are the Sidelights that come on when the headlight switch is at the first "on" position on a UK spec Scirocco?
Front: The ones you've labelled City lights (Bentley calls them parking lights :grins: )
Rear: Euro Tail light
What bulbs are Dipped-beam headlights that come on at the second "on" position on a UK spec Scirocco? (I think the H4 lo)
Front: H4 Lo (my mainbeam reflector does not have the high beam bulb, it uses the separate H1 bulb in the adjacent light unit)
Tempest
My Mk1 Rocco, Rado and 928
Tempest
warum ziehst Du Dir nicht einfach ne Strippe vom einen NSL rüber zum anderen ?
In English: Why not run a separate wire from the one rear fog light to the other one?
That´s exactly how it is done on my Storm, see pics :grins: See the grey-white wire for fog light juice. First pic is the right hand side cluster connector, 2nd picture is from the left hand side cluster, where the wire for the right-hand side rear fog light is simply branched off with a Scotch-lock connector.
Tempest
Doug Teulie
Beitrag von Doug Teulie »
Tempest hat geschrieben:In English: Why not run a separate wire from the one rear fog light to the other one?
[ATTACH=CONFIG]48550[/ATTACH][ATTACH=CONFIG]48551[/ATTACH]
Tempest
Don't the L and R sides have different fuses? Not that you need your tail fogs to have two fuses....
Doug T (California USA)
76 MK1 Scirocco 1.8 S8V
80 MK1 Scirocco 1.8 S8V
87 MK2 Scirocco 1.8 16V
Tempest
Nope, as you can see from my wiring pics, both fogs run off the same grey-white wire.
Tempest
Doug Teulie
This is how my car was setup before I added the extra wires.
My tail lights are split to different fuses. Perhaps that is for parking with the outside on only?? We don't have that feature.
el loco rocco2124
Dirk hat geschrieben:warum ziehst Du Dir nicht einfach ne Strippe vom einen NSL rüber zum anderen ?
ich habe meine beiden NSL getrennt angesteuert, aber das ist ne andere Geschichte :hihi:
Grüße
Dirk
dachte immer das man nur ein nebellicht hinten haben darf. aber da lag ich wohl falsch oder?einfach n kabel rüber legen und gut oder wie.
das lichtspiel is ja mal ne lustige sache!!
sanni
Beitrag von sanni »
Ist dafür der Nebelscheinwerferschalter im Innenraum? Hab mich schon immer gefragt was der soll weil ich doch garkeine Nebelscheinwerfer hab, also vorne.
Tempest
sanni hat geschrieben:Ist dafür der Nebelscheinwerferschalter im Innenraum? Hab mich schon immer gefragt was der soll weil ich doch garkeine Nebelscheinwerfer hab, also vorne.
Yes :-)
Tempest
